rsx fog lights
Checking it twice
Fog lights aren't meant to be used with High Beams, the dispersion pattern is low and to the ground to cut under the fog, high beams in the fog are almost useless because of lighting up the haze and not cutting through it. If you want additional lighting with your high beams get driving lights.
Acura RSX Type S
Originally Posted by gmjg
does anyone kno how to make the oem rsx fog lights come on with the parking lights and the hi-beams
thanks
thanks
here is a wire you need to cut and slice
Acura RSX Type S
do you cut it off the switch the put a wire from the wire to the ground or from the switch to the ground
thanks for the help
thanks for the help
Acura RSX Type S
I-MOD is the one that came up with this mod which will let you turn on the lights while having your parking lights on.. and it will flash with you if you have it on when you press the lock button.
