intermitten starting problem
Old Sep 18, 2003 | 07:59 PM
chargedmr2's Avatar
chargedmr2
Default intermitten starting problem
I had the auto-tensioner replaced on my 99 prelude last week and have since had a strange starting problem. It has happened twice. When I go to start the car the engine turns over about half a turn and just stops. I turned the key off, tired again, and it starts fine. What could this be????
Old Sep 18, 2003 | 08:52 PM
fizzbob7's Avatar
fizzbob7
90 accord h22a
Default Re: intermitten starting problem
timing might be off....take it back and have them check it with a light
Old Sep 19, 2003 | 07:41 PM
chargedmr2's Avatar
chargedmr2
Wouldn't it run like shit if the timing was off that bad? It happened again tonight. It sounded like the battery was almost dead. It barely turned over several times then turnover sped up a bit and started after 10 or 15 turnovers. Battery is fine though. Once running motor sounds fine also. I turned it off and the same thing happened when I started it again. What the Hell!! Any more advice out there???
