oil cooler installed
Old Sep 8, 2003 | 06:49 AM
Mr.Badguy's Avatar
Mr.Badguy
Hey boost, how hard was it to remove your airbag? For me, its either put a screen there or do my whole dash in plasma screens.
(as if I had the money)
Old Sep 8, 2003 | 12:47 PM
machinehead's Avatar
machinehead
i removed the passenger airbag in 10 minutes. philly screws and 10 milli nuts.
Old Sep 8, 2003 | 03:25 PM
importsyn's Avatar
importsyn
What size hose do you need,outer diameter in "imperial" measurements (ie)3/8,1/2,etc.).I might be able to get you some from my work.We make OEM engine oil cooler lines,tranny lines and A/C lines.Let me know I might be able to hook you up.Hope this helps.:thumbup:
P.S. The lines are tensile tested to hold like up to 1100psi but OEM spec is only like 8-900psi.If it's not what you're looking for than ignore this post.
Old Sep 8, 2003 | 06:51 PM
boostlee's Avatar
boostlee
thanks anywanys importsyn, i already bought the lines and murrays gave me a better deal
Mr.Badguy just as machinehead said, it takes about 10-15mins, very simple
make sure you put the red connector on the air bag connector to prevent it from going off.
i pryed off the fastners holding on the top part of air bag and put it back on the dash, so the airbag is now gone but it still looks stock
Old Sep 9, 2003 | 11:50 AM
importsyn's Avatar
importsyn
A better deal than free???Oh well just thought I'd try and help out,maybe another time.
