front strut bar
Old Aug 14, 2003 | 01:18 PM
Clockwork's Avatar
Clockwork
Default front strut bar
Is it worth it to just buy the front strut bar to go across the engine bay? Or would I have to make other mods to make buying the front strut bar worth it?
Basically, will just buying this one piece make a difference in handling of my 2001 lude?
Clockwork
Old Aug 14, 2003 | 10:17 PM
monkey's Avatar
monkey
#212
no. strut bars are for the most part, not very effective. ludes are already pretty rigid laterally, and don't need c pillar bars, strut tower braces, or any of the stuff the DC2 guys need. some will say they feel a difference...
the single most effective bar mod you could do is a stiffer rear sway bar, or removing your front sway bar, to lessen the understeer but either one of these mods really changes the way your car handles and drives so be forewarned.
Old Aug 19, 2003 | 06:49 PM
importsyn's Avatar
importsyn
I agree I've got all the tie bars you can buy other than the C-pillar bar and there isn't really a noticeable difference in the cars handling.Don't get me wrong I'm sure they do what they're supposed to when I'm autoXing but I went with Suspension Techniques front and rear sway bars and noticed more.I disconnected my front sway bar and now my car reacts the way I want it too but at first spooked me on more than one occasion as it tends to oversteer now.Bottom line buy a rear sway bar or if you don't have the money disconnect the front one just be careful!!!I wouldn't bother with tie bars unless they're just for show or you've done everytheing else in your suspension.
Old Aug 20, 2003 | 09:04 AM
monkey's Avatar
monkey
#212
yeah, if you disconnect your front sway bar, and don't have a lowered car, you might experience some pretty bad body roll...
Old Aug 20, 2003 | 09:47 AM
drift's Avatar
drift
Flaccid Member
because of the lack of a significant support beam in the rear, separating the cabin from the rear subframe, you could benefit from a rear strut tower bar or some other more rigidly designed brace to keep your rear subframe from twisting and responding erratically and independently from the rear suspension.
as for the front, the struts are mounted so close to the firewall on Hondas, chassis flex in the front subframe is minimal if any at all.
Old Aug 20, 2003 | 02:13 PM
epoxy's Avatar
epoxy
Regulator
i have a upper front and lower rear bar.
i noticed a difference in handling, actually. but then again, i put them on at the same time. i agree with drift that the front brace is too close to the firewall anyways.
they are cheap parts anyways... your choice i would def. invest in a rear one though. goodluck
