changing oil in SH
Old Jun 2, 2003 | 10:07 PM
epoxy's Avatar
epoxy
Regulator
Default changing oil in SH
I've never changed my oil in my prelude (too low, even on my tire ramps), but isnt there a difference in SH and BASE? How would you go about changing it in a SH? (i heard it was harder to get it)
thanks
Old Jun 3, 2003 | 12:48 AM
jc836's Avatar
jc836
The oil filter is located closer to the brake booster on an SH. As to the pan plug-that should be easy enough with your ramps. ALWAYS use a new crush washer on the pan plug.
Old Jun 3, 2003 | 06:15 AM
4thGenReady2Go's Avatar
4thGenReady2Go
Throbbing Member
And it might take a little more effort to work around the ATTS to get to the filter, or at least, that's what I've heard. Nevertheless, take your time, a proper job always beats a speedy one. No matter how much someone can downplay a "simple oil change", if you muck it up, it could cost you the most expensive parts in your engine ... funny how that works eh? Good luck.
Old Jun 3, 2003 | 03:18 PM
THATPRELUDEGUY's Avatar
THATPRELUDEGUY
I suck!
I change my filter out from on top on my SH. I doubt you can even get to it from the bottom. Oil drain is the same spot.
