96 prelude clutch question please help!
Old Apr 30, 2003 | 04:35 PM
ATL HomEgRowN's Avatar
ATL HomEgRowN
Default 96 prelude clutch question please help!
yesterday i noticed i was losing pressure in the clutch pedal but was able to change gears fine. this morning when i got ready to start her up and drive to the shop i put my foot on the clutch and *bam* it went straight to the floor. i was able to start it up but could not select a gear until i turned the car off. and of course its raining and lightning like hell here so i couldn't do any other investigating today. just hoping someone could help me out here. btw, it's a 96 si.
Old Apr 30, 2003 | 05:35 PM
honda guy's Avatar
honda guy
did you check the resivoir its probably empty. if so look under the dash at the clutch pedal were the push rod comes through if its wet then the clutch master is leaking, if not check the slave cylinder on the trans that may also be leaking
