Differences between base Lude and Lude SH?
Old Mar 19, 2003 | 09:54 AM
ur31337's Avatar
ur31337
Colby
Yea, I didn't stop to think about an aftermarket LSD. Fawk ATTS
Old Mar 19, 2003 | 10:20 AM
preylude99's Avatar
preylude99
just curious, how much would it cost for an aftermarket lsd?Cause it might be cheaper to get a base and go LSD then get the SH.
Old Mar 19, 2003 | 10:26 AM
ur31337's Avatar
ur31337
Colby
Well, for a B-series tranny, Quaiffe gets $800.
Old Mar 20, 2003 | 03:43 AM
drift's Avatar
drift
Flaccid Member
Originally posted by preylude99
well IMO it just depends on the going price of what you can get each one for, if the SH is A LOT more between the ones you have picked out, then it may not be enough to justify getting it over the base, as you can save the money for some mods for the car, but if you want the ATTS then go for it, thats the only MAJOR difference between the two.
not the only major difference.
ATTS is one, but the SH also features a revised front suspension with improved geometry for better cornering ability.
the motor supposedly has some slight improvements to increase HP by 5-10hp over the base model.
as for ATTS, it's good for cornering, but it's limited on total power output and it doesnt work while in a straight line. the system only transfers torque during cornering, unlike a true limited slip system like the Quaife that works all the time that is also unaffected by total torque output.
Old Mar 20, 2003 | 12:01 PM
94prelude_v-tec's Avatar
94prelude_v-tec
Punk Rock
Go to www.osakajdm.com I think JDM lsd from them is like $200 when you buy an engine, I dont know if they charge more if you buy it seperate or not but its worth checking.
Old Mar 20, 2003 | 01:45 PM
preylude99's Avatar
preylude99
drift, yea I forgot about the suspension part but I figured he would know about that if he was going to do any research, as for the 5-10 HP, I thought the specs were exactly the same, or does the SH have a little more HP even though the specs dont indicate it?
Old Mar 20, 2003 | 02:57 PM
drift's Avatar
drift
Flaccid Member
the SH was always rated with 5 more hp over the base model.
1997-98 Base 195, SH 200
1999-01 Base 200, SH 205
