no heat
Old Dec 16, 2007 | 09:57 PM
Niceprelude's Avatar
Niceprelude
Default no heat
suddenly the heat are gone now it blows cool air
Old Dec 17, 2007 | 04:25 AM
shivers's Avatar
shivers
Moderator Alumni
thermostat replacement? start there.
2005 s2000
Old Dec 17, 2007 | 09:17 AM
mberndt's Avatar
mberndt
My guess would be that you lost some coolant, either thru a leak or being burned, and now there is an air pocket in the cooling system. Check the coolant level, and also check the coolant to see if there is an oily residue on the surface. If the coolant is filled all the way up, then it is most likely your thermostat.
Old Dec 17, 2007 | 10:08 PM
Niceprelude
coolant is fine so how much is the thermo going to cost estimate
Old Dec 19, 2007 | 10:01 AM
Bones45's Avatar
Bones45
wow.. ever hear of google?
Old Dec 26, 2007 | 09:29 AM
SNoWMoNKeY's Avatar
SNoWMoNKeY
How can you check for an air pocket? I changed my thermostat but still have no heat.
Old Dec 28, 2007 | 01:30 PM
blacklude's Avatar
blacklude
Default no heat
the bleeder valve is above the thermostat. if bleeding does not work. run the engine. there will be 2 hoses at the rear of the motor that go to the fire wall. these hoses are for the heater core. with the engine warm check if both hoses are hot. if they are both hot check the function of coolant valve to the heater core. this valve operates with a cable to the heater control. have someone adjust the heater from cold to hot, watch the valve while they do this and make sure the valve moves. remember dont open any cooling system components when hot. if the valve moves and both hoses are hot u might need a heater core. u can try running a cooling system flush through the system and install new coolant.
Old Jan 23, 2008 | 08:37 AM
asheylarry's Avatar
asheylarry
is your engine warming up completely? how long does that take? if the engine is warming up normally, and your upper hose is hot as well as the lower, then you do not have a thermostat problem. if the t-stat was stuck closed you would overheat fairly quick and boil your coolant. if it was stuck open you would take forever and ever to warm up. if the tstat is fine and you have no hot air then you need to check for a plugged heatercore (not likely) or a malfunctioning blend door (bad lever, blend door motor, or stuck blend door). hope this helps also, make sure both lines going to and from the heater core (the only 2 heater coolant hoses that run into the firewall) are hot.
Old Jul 23, 2025 | 10:06 AM
daryelcorran's Avatar
daryelcorran
Ziken
92+ Civic/EL & Del Sol
5
Jan 10, 2007 07:58 AM
Flatland2D
3
Dec 25, 2005 10:13 PM
jmg
Minivan, SUV, & Truck
2
Mar 23, 2005 05:23 PM
1CleanLS
11
Jul 26, 2004 06:04 PM
civicfan8
5
Apr 11, 2004 02:16 PM
