brake problem
Old Oct 5, 2007 | 01:14 AM
DarkStarr's Avatar
DarkStarr
Shake n Bake!
Have you checked your fluid level?
Old Oct 8, 2007 | 09:12 AM
blown5thgen's Avatar
blown5thgen
are the rear brakes drum on that still? if so adjust the rear brakes that can be doing it. also another problem could be that there is air somewhere in ur brake lines. try bleeding the brakes starting with the wheel furthest from the master cylinder (right rear) and work your way closer. left rear right front left front.
