-Problems-
Old Apr 20, 2007 | 08:36 PM
94 Prelizzle's Avatar
94 Prelizzle
Honda Prelude
Default -Problems-
Sup to all,.........all of a sudden my brakes are really spongy, i just changed the pads a week ago and they worked fine, now i hafta push the pedal all the way to floor and hope she stops....theres no leaks, no air in the lines, resiviors full " or however you spell it " , and also my shifter isn't working right, it's really hard to shift, someoen mentioned something about a vacuum pump or something...iono i'm not mechanicly inclined so any help at all is greatly appreciated thanx 94 Honda Prelude S " F22A4 "
Old Apr 21, 2007 | 05:04 PM
Rich's Avatar
Rich
Your master cylinder might not being holding pressure.
Old Apr 23, 2007 | 01:00 PM
mberndt's Avatar
mberndt
The brakes are vacuum-assisted power brakes, but the vacuum assist doesn't come from a vacuum-pump, it comes from the vacuum created by the engine (Vacuum in Intake manifold)...
So, if you're positive that the system is free of air, the reservoir is full, and you don't see any leaks, then chances are the brake booster is not getting any, or enough vacuum due to a leak somewhere.
Check your vacuum lines and seal around the brake booster.
Good luck!
