Top Speed
Old Dec 7, 2006 | 02:43 PM
WhiteNoiz's Avatar
WhiteNoiz
Originally Posted by 99PreludeSh
120 thats it?
yup
Old Dec 7, 2006 | 04:07 PM
b-bomb's Avatar
b-bomb
I drive an accord, its a 91, 4door, 5spd and NA and I got 135 a couple times, but definately 130 easy. All I have is intake exhause and a chip.
Old Dec 8, 2006 | 08:54 AM
18crx's Avatar
18crx
stock booster
my speedo goes to 150
Old Dec 9, 2006 | 10:02 AM
Mkazm83's Avatar
Mkazm83
Snapping bolts
The stock speedo gets inaccurate at higher speeds, its probably off by 10-15mph at 140+
Old Dec 9, 2006 | 03:09 PM
b-bomb's Avatar
b-bomb
10 -15mph is a lot to be off, even if it is only when you get to the higher speeds.
Old Dec 9, 2006 | 07:57 PM
Driverman5777's Avatar
Driverman5777
10-15 positive or negative?
Old Dec 9, 2006 | 09:37 PM
lufkintravis's Avatar
lufkintravis
If the little roadside radar thingy they just put up is right, my accord reads 50 at about 45...
Old Dec 9, 2006 | 10:06 PM
Mkazm83's Avatar
Mkazm83
Snapping bolts
Negative.
Old Dec 10, 2006 | 07:59 PM
SirHybrid's Avatar
SirHybrid
I've hit 130+ on the speedo with loads of umpfh left. And I believe we (5th Genners) top out at about 147 (on the speedo) which apparently is about 140 real MPH.
97 Prelude Stock Specs
Old Dec 11, 2006 | 11:40 AM
mberndt's Avatar
mberndt
Really? Where is your evidence??
While I agree it will prob be off by some amount, unless you change the wheel size or tires, I don't see how it could be off by 10-15mph...
In that case, why buy V-rated tires, if we're only able to get to 125? Why not use H-rated tires which are rated to 130mph?
