Help! Car wont start!
Ok i goto start my car to goto work this afternoon, i push down the clutch and turn the key like normal and everything turns on cd player antenna my lights everything, but the car.
The car doenst turn over nothing , i checked the fuses battery starter alternator all that stuff i unplugged the ecu and battery i unplugged the clutch sensor and plugged it back in and still nothing
my car had this issue before where it wouldnt start right off the bat i would have to just turn the key twice....now i turn the key a lot and still nothing
i turned the key about 50 more times with the clutch in and all of a sudden it started!
but thats not the end of it cause now i am at work and it wont start again and ive tried everything
anyone know what would be the problem could be and how to fix it??
did u check if ur getting spark? yea before my car sometimes didn't start at random times, like it will start after i turned the key like 30 times. i had to replace my ignitor(icm) which is located in the cap/rotor.
well i was able to push start the car
i just dropped off the car at the shop they tested the starter and relay they both checked out good
dono if i am getting a spark though
i am able to push start the car can i still do that if i dont get a spark?
