Help! Car wont start!
Old Nov 15, 2006 | 09:25 AM
Lynxx's Avatar
Lynxx
Methanol Drinker
It still sounds like the ignition switch is at fault. You can have a bad I/S and still have spark...
Old Nov 16, 2006 | 12:27 AM
preludedriva's Avatar
preludedriva
it might be the swtich but it might be the alarm if it is then ima have circuit city fix it if anythign ima hook it up to a starter switch
Old Nov 16, 2006 | 09:46 PM
Nirvanaspartan's Avatar
Nirvanaspartan
solenoid?
Old Nov 20, 2006 | 02:50 PM
preludedriva
its not the starter at all because the shop its at getting turboed jump started the starter and it fired right up
Old Dec 3, 2006 | 01:54 AM
numark34's Avatar
numark34
then it must be your battery low charge amperage or just dead
Old Dec 4, 2006 | 09:54 PM
stereo's Avatar
stereo
it could be an ignition switch or if you have a aftermarket alarm usally code alarms are famous for causing the problem your describeing because the open circut starter kill pits the relay causeing it to fail.
Old Dec 5, 2006 | 09:30 PM
numark34's Avatar
numark34
if you think its the alarm find the control box and unplug the harness with the key switch open then plug it back in ur alarm should go off dont worry it will shut off on its own so leave it be dont use your remote the alarm will reset itself after about 15 minutes to ahalf hour then give it ago it should start back up if its your alarm i mean ur security system is at fault
Old Dec 9, 2006 | 08:30 PM
preludedriva
it was the start solenoid i guess what happened was there was a short from the alarm and it shorted out the solenoid
