air/fuel gauge
Old Jun 14, 2006 | 01:16 PM
jesseunvoas's Avatar
jesseunvoas
Default air/fuel gauge
so im in the process of installing all my guages and finished the volt meter and oil presure now im doing the a/f next but i need to know what wire is the signal wire
so if anyone has installed one of these could you tell me plz
jesse
Old Jun 14, 2006 | 01:23 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
All those gauges are useless unless you are boosted
Old Jun 14, 2006 | 08:51 PM
jesseunvoas
well i am planning on it but now im just getting the simple things out of the way now do you know what the signal wire is or did you just wanna put in your 2 cents?
Old Jun 14, 2006 | 09:41 PM
bb4jdmlude's Avatar
bb4jdmlude
H22A
u have to splice the purple wire it was on my a/f to the white wire on the o2 sensor
Old Jun 15, 2006 | 06:05 AM
jesseunvoas
but i think there were 2 whites
Old Jun 15, 2006 | 10:16 AM
bb4jdmlude's Avatar
bb4jdmlude
H22A
white with black dashes on it i belive i can check on my car but it is so low
it is a tight fit
Old Jun 15, 2006 | 10:23 AM
jesseunvoas
it is a tight fit
now would it be on the main harness in the car as well?
Old Jun 15, 2006 | 11:57 AM
asheylarry's Avatar
asheylarry
yes it goes into the main harness. but its in a giant loom so you should just trace it up from the o2 in the exhaust manifold and carefully attatch where it wont be exposed to direct heat. 3m makes something called a terminal splice lock or some fuckin name like that. it makes a clean connection and you dont have to tape the piss out of the connection
Old Jun 15, 2006 | 01:18 PM
jesseunvoas
ok thats what i thought so i need to trace the wire and then i think i wanna keep the wire in the car not and not attach it under the car just incase something melts
thanks if i figure it out i definetly post up pics and everything
Old Jun 16, 2006 | 11:23 AM
asheylarry's Avatar
asheylarry
yep, keep the connection high and dry
