why is my engine skipping?
Old Jun 6, 2006 | 02:48 PM
dr125m's Avatar
dr125m
Default why is my engine skipping?
i have a 1991 prelude 2.0si i just put new plugs, wires, cap,and rotor on. i also had a can(muffler) put on at the same time and now the car skips after it warms up a little bit. What is wrong?
Old Jun 6, 2006 | 06:52 PM
mybluelude's Avatar
mybluelude
WILD BILL
I had a simular problem with mine. What kind of plug wires did you get? The originals I found, have vents in them, check to see if you plug wires are popping up, they will look like they are still on, but if you push on them they will go down. Always use factory parts when messing with the electronics of a honda, the factory knew what they were doing.
Old Jun 7, 2006 | 07:15 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Yeah those wires pop out, my 88 used to do it every once in a while. Do you have a check engine light?
Old Jun 7, 2006 | 09:14 AM
dr125m's Avatar
dr125m
yes i have a check engine light but its been on for awhile. It goes on and off whenever it feels like it and never bothered the performance before.Thanks for the info by the way
Old Jun 7, 2006 | 10:15 AM
97civicEXVTEC's Avatar
97civicEXVTEC
Does it shake like it's going to stall?
Old Jun 7, 2006 | 10:24 AM
dr125m's Avatar
dr125m
yes it shakes like its going to stall. Feels like i lose two cylinders when it starts to skip.
Old Jun 7, 2006 | 10:57 AM
F22B Prelude
Rachel Bilson
Find out what code your running at let us know
Old Jun 9, 2006 | 05:25 AM
questip's Avatar
questip
Like to drift!!!
Lets see if I can help some. If its skipping it may be the spark like they the other people said. It might even be water in the engine if u have a cold air intake. Does it skip while driving? It may even be a sensor, but check the ecu for codes.
Old Jun 9, 2006 | 08:48 AM
RightCoast_Chrs's Avatar
RightCoast_Chrs
yeah deffidently either a spark plug problem or i think that maybe some water deffidently could slipped into the engine, same thing happened to one of my buddies a while back his car was skipping and he took it to a shop and some water got into the engine....
Old Jun 9, 2006 | 11:15 AM
dr125m's Avatar
dr125m
how do i check my trouble codes?
