why is my engine skipping?
Old Jun 9, 2006 | 11:18 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Originally Posted by dr125m
how do i check my trouble codes?
Should be a connector behind your dash where your cd players at, put a paper clip in there or a piece of wire connected together...turn ignition on (don't start car) and watch the Check Engine Light flash on the dash.
____ (long flash) = 10
__ (short flash) = 1
Be carefule cause if its multiple codes they run back to back
Old Jun 19, 2006 | 05:38 AM
questip's Avatar
questip
Like to drift!!!
Or just go to autozone and have them do an ecu diagnostic. Its free and accurate.
Old Jun 19, 2006 | 01:13 PM
FooD2000's Avatar
FooD2000
Still Water
91' prelude which is going to be obd-1. Autozone doesn't have an obd-1 scanner for hondas (they do for toyota, ford, crysler and GM), a
t least not in San Diego.
Old Jun 19, 2006 | 01:14 PM
F22B Prelude
Rachel Bilson
Yeah they only do OBD-II for Honda's.....I've already tried h:
Old Jul 1, 2006 | 09:37 PM
PoloBoy's Avatar
PoloBoy
Default this just happened to me about 3 months ago
Ok don't immediatly go out and pay someone for a job like this but deffinetly check, from what you say and whay you just purchased I'm going to throw out all those possibilities and say its deffinetly not water in the engine, or spark of any sort but im certain your timing belt is just about done for, your probably missing a tooth or if your unlucky like me your probably missing anywhere from an inch to five inches in a row of teeth on your belt. check your belt for tightness also start your car and listen to the belt even if you have the covers on trust me you will hear a ticking or slapping noise. When your belt starts wearing out trust me you will lose power and it will send your check engine light into confusion but don't wait too long to atleast find out if im right or not cuz once that belt breaks or gets to that 5 inch gap of missing teeth trust me you will be replacing your head!!!
Goodluck to whatever it is but from experience trust me I got some wierd shit that has happened to me in my lude im almost certain thats the cause.
later, luders
