93 honda prelude 4ws need help with 4ws
I have a 93 honda prelude I am having problems with the 4ws. I have replaced both from abs sensors they might be bad. The 4ws and the abs light were on until I replaced the abs relay and now both the lights turned off but the 4ws still don't work. Any help would be appreciated.
Thanks
Josh
Thanks
Josh
I have a 97 JDM 4ws lude. Whwn you do any work on the 4ws you have to reset the 4ws to find center, left & rigt 15 degrees. If yours is computerised, then thats the deal with it and it wont work untill you do that. Or you can just try removing the negative wire fot 60 sec to clear the error code, but i doubt this alone will help.
Do you have a rear actuator unit on your lude ?
