Prelude Axle nut wont come off Awww help!
i tried a 440lb torque impact wrench and a breaker bar with a 3foot entension on it
this axle nut wont budge
does any1 have any advice? i have to try to put some new studs in
Glad you already have new studs, because it sounds like it's siezed on there. Never heard of that happening before. I'd say, keep trying, and you might break the stud before the lug nut turns. Either way, it's off.
Dan
Dan
yes its easy to break the studs off but i cant get the new ones in. there is not enough clearance
the axle nut is really really hard. i called the shop they want 100 bucks to do it. is it normal for the axle nut to be this hard to remove?
i took it to a tire shop
they used a 1/2 inch impact wrench made by airtech or airtech and i researched it and it has 1000lbs of torque
they had absolutely no problems taking this axle nut off it came off with ease for them with no effort at all
i have an american tool exhange twin hammer impact wrench i got from ebay with 440lbs of torque
im an idiot this tool i have is junk airtech worked so good
