Quick Cold Air Intake question
Old Sep 17, 2002 | 09:07 PM
93PreludeSR's Avatar
93PreludeSR
Default Quick Cold Air Intake question
Hi everyone. I have a few questions that I am wondering you can help me with:
1)Does your cold air intake just kida hang there, or is it connected by a bracket so it doesn't move around?
2) Does your CAI rub against the newly created 'hole' in your car? If so, what do you use to prevent this?
3) My Filter hangs pretty damn low. It actually touches the bottom of the car. Is this bad?(For air flow etc...)
I appreciate any comments you may have. :thumbup:
Old Sep 17, 2002 | 09:29 PM
TheChineseChap's Avatar
TheChineseChap
I used a hammer to open the "hole" so that there would be no rubbing, bumping or grinding.
Old Sep 18, 2002 | 06:00 AM
RenieLude's Avatar
RenieLude
formerly PreludeChick89
Default Re: Quick Cold Air Intake question
it has a rubber piece that does attatches to the body.. such as the bracket you are talking about...
yes it does... bicycle rubber will fit well to prevent the CAI from rubbing on the metal and scratching.. but in some cases you will need to hammer the hole open... (or cut it out like mike did.. hehe)
no it is not... b/c of the "stone guard" it will still somewhat protect the filter and that is where the air comes from with the orignal intake.. that's another reason why you bought the cai instead of the short ram.. the short ram stays in your engine and just sucks up the hotter air in the engine bay..
Old Sep 18, 2002 | 07:59 PM
SK LUDE's Avatar
SK LUDE
You should dry to push your filter up more. There is nothing wrong with it touching the splash shield but its better the the filter be more up on the pipe rather then on the edge of it.
As far as the whole concerned.... you can either bend the metal down to fit the pipe or grind it off with a dremel or air gun. Then take a regualr rubber hose make a slid in it with a blade ...horizontally that way you open up the hose then put it over the sharp edges and this will protect your CAI from damage.
Some people didnt do the above and have tiny holes developed from continuous rubbing.
Old Sep 19, 2002 | 06:36 AM
RenieLude's Avatar
RenieLude
not to mention the terrible noise that sounds like something is very wrong with your car!!
92_Lude_Si
Prelude
2
Feb 19, 2006 06:59 PM
VTEC-Power
92+ Civic/EL & Del Sol
16
Jun 27, 2005 03:58 PM
jeromejr
Accord
9
May 2, 2005 03:21 PM
Johnny B
Prelude
6
May 26, 2004 07:55 AM
23matt23
Accord
7
Jul 16, 2002 10:32 AM
