Rough clutch
Old Feb 13, 2006 | 02:46 PM
MellowGold's Avatar
MellowGold
Default Rough clutch
'ello,
I have a 5th gen Prelude at 98k miles. I just bought it about a month ago. Recently, the clutch seems to be getting rough. For example, it takes a bit of effort to get it into gear when downshifting. It's really only downshifting, and only on 1st, 2nd, and starting in reverse. It's not horrible yet, but it seems to be getting worse. Any ideas what it is? My other car (89 Accord) had a cable clutch, so I really have no experiance with hydrolic.
Thanks.
Old Feb 13, 2006 | 03:40 PM
97civicEXVTEC's Avatar
97civicEXVTEC
I would put some money aside just in case your clutch decides to take a shit on you. That's what is sounds like to me.
Old Feb 13, 2006 | 05:59 PM
MellowGold's Avatar
MellowGold
Thanks, that was all I was wondering.
Old Feb 14, 2006 | 11:34 AM
Phateless's Avatar
Phateless
S2K compatible
sounds more like your clutch master cylinder to me. check the floor mat under the pedals. is there a stain? any evidence of dripping? heck, maybe you just need to bleed your clutch fluid.
Old Feb 14, 2006 | 02:59 PM
asheylarry's Avatar
asheylarry
if its only in first and second, and deffinetly not in 3 4 or 5 then you probably have synchro problems. reverse doesnt have a synchro and on some cars (all of my hondas) i have to put it into first gear to stop the input shaft AND THEN reverse
but check for fluid leaks just incase
Old Feb 15, 2006 | 12:26 AM
borass07's Avatar
borass07
yeah definalty a synchronizer problem, will need a rebuild. Where you located?
Old Feb 15, 2006 | 04:19 AM
mybluelude's Avatar
mybluelude
WILD BILL
IF YOU DO REPLACE THE CLUTCH, MAKE SURE TO GET THE FLYWHEEL RESURFACED!!!
Old Feb 15, 2006 | 04:24 AM
Phateless's Avatar
Phateless
S2K compatible
before you rebuild, try changing the tranny fluid (ONLY use real honda mtf from the dealer), make sure your clutch is bled/adjusted and the m/c isn't leaking, and learn to rev-match. if you're still having trouble, maybe it's time for a rebuild.
