Possible alternator problem.. please help.
Old Jan 26, 2006 | 06:23 AM
Scorned's Avatar
Scorned
Default Possible alternator problem.. please help.
Hey guys.. here's my problem.
1995 Prelude VTEC H22
This morning, my car struggled to start, and on the way to work, the tach and speedo dropped to zero, my radio cut out, and my dash dimmed. The car still ran fine, no stuttering or whatnot. I get to work, shut it down, and tell my friend about it, so we go out to poke around, and the car won't start. The starter clicks and that's it. So we hooked up some cables and jumped it no problem. I shut it off after the jump and it wouldn't restart. Does that sound like the alternator? Also, if I replace the alternator myself, is there anything I should know while removing it, and is it going to be a tough removal? I know to unhook the battery, but beyond that, is it as simple as removing the heat shield and unbolting?
Thanks in advance.
Old Jan 26, 2006 | 06:29 AM
2legit2quit's Avatar
2legit2quit
You Big Dummy
The removal is pretty simple, just a few bolts. But before you go and relace it, I would get it and the battery tested. Autozone and places like that do it for free. To me, it sounds like your battery is what is going bad. How old is it?
Old Jan 26, 2006 | 06:37 AM
Scorned's Avatar
Scorned
Heh.. the battery is about 2 weeks old.
Old Jan 27, 2006 | 05:18 AM
Scorned's Avatar
Scorned
<--- noob
My grounding wire had come loose.
Old Jan 27, 2006 | 02:38 PM
NUUUBIELUDDIE's Avatar
NUUUBIELUDDIE
i have some bad car symptoms that i suspect is the alternator the symptoms are sometimes i get realllly weak start (very rare happens every 1 out of 30-35 start ups) and prob the car cranks but doesnt start up at all once every 60-70 start ups... could this be the alternator or teh battery..
