Headlight Problem
Old Jan 19, 2006 | 02:58 PM
ninarco's Avatar
ninarco
Default Headlight Problem
Whenever the blinker is used the headlights will sometimes shut off and have to be turned off and then turned back on to work. This occured for a few days and recently the left head light stays off altogether and doesn't work anymore. I have checked the headlight fuses and they are fine. The headlight is fairly new and should not be broken. Does anyone have an idea of the problem and a possible solution to remedy the problem? Thank you.
Old Jan 20, 2006 | 05:56 PM
mybluelude's Avatar
mybluelude
WILD BILL
IF THE CAR WAS EVER HIT IN THE FRONT, IT COULD BE SOMETHING AS SIMPLE AS A PINCHED WIRE, CHECK YOUR HEADLIGHT AND MARKER LIGHT WIRING HARNESS.
