help w/ el gauge conversion 93 lude
Old Jan 4, 2006 | 02:08 AM
kensta's Avatar
kensta
Default help w/ el gauge conversion 93 lude
i need help with my 94+ el gauge conversion on my 93 prelude. everytime i signal left or right both of the blinkers blink and none of the blinkers blink when hazard light is on. this is weird, when i cold start the car both blinkers STAYS on. they signal correctly but ONLY until the car is warmed up then it turns off and does the same shit i mentioned above where both blinkers blink when turning left/right. also my dimmer control doesn't work i want to be able to adjust the brightness so it can be bright at night like before i did the coenversion. the harness i got with the gauges was cut in a few areas and some adapters was not cut. i plugged in the adapters correctly, but then when connecting the adapters that i cut off, some wires are not matching or i end up with extra wires. i believe i might've wired wrong but where do i start?
Old Jan 4, 2006 | 06:41 AM
2legit2quit's Avatar
2legit2quit
You Big Dummy
I don't know if this will help, but here is a list of where all the wires go. I got it from Vancouver Prelude Club.
(ORIGINAL)
Harness H
1. Yellow -- power
2. Pink -- speedometer
3. Splice the red/green wire from under the hood near the fuse box and run to pin -- power
4. Red/Black -- dimmer wire
5. Black -- ground
6. Orange
7. No wire
8. Light green (you need to splice the wire from the dash clock harness & run it to the pin) -- trip mileage memory
9. No wire
10. No wire
Harness J
1. No wire
2. No wire
3. No wire
4. Green/yellow -- right blinker
5. Red/blue -- high beam
Harness M
1. Blue/silver spots -- tachometer
2. Black -- ground
3. Red/yellow -- high beam
4. Green/blue -- left blinker
5. Blue -- SRS
(UPDATED)
Harness H
1. Yellow -- power
3. Yellow -- Power
5. Black -- ground
6. Orange
7. No wire
9. Red/Yellow
10. No wire
Harness J
1. No wire
2. No wire
3. No wire
Harness M
2. Black -- ground
4. Green -- left blinker
5. Blue -- SRS
