Heat Shield
Old Oct 19, 2005 | 04:01 PM
beier's Avatar
beier
A Philanthropical Fruit
The heat sheild shouldn't effect the exhaust tone at all, the only noise it could make is rattling. That is, if we're talking about the same thing.
Old Oct 20, 2005 | 03:31 AM
katana62678's Avatar
katana62678
My heat shield rattles, but only when the exhaust is cold, and it is cold outside. Putting a new one on won't always fix the rattle. I'm assuming you have an aftermarket exhaust. If it rattles with the stock exhaust, then a new shield may fix your problem.
Old Oct 20, 2005 | 05:40 AM
shylude's Avatar
shylude
can you use a base header/heat shield on an SH?
Old Oct 20, 2005 | 05:41 AM
shylude's Avatar
shylude
Default Gasket
Originally Posted by Baseballj1j
Raspy sound is the gasket between the manifold and the down pipe.
i have that raspy sound too. should i replace that gasket?
Old Oct 20, 2005 | 05:46 AM
katana62678
I'm not sure, but I don't believe so, because the heat shield, I believe is right near the ATTS controller, and may be a different shape/size. Someone else may be able to comment with a more definate answer.
Old Oct 20, 2005 | 08:48 AM
jc836's Avatar
jc836
The heat shield on the manifold is the same for both Base and SH. The other shields are somewhat different due to pipe lengths and the ATTS. The shield on the CAT should be the same. Pricing is dependent on how nice the you and the dealer parts people are about discounts. Then again you could order what you need online or use that price as "leverage" to get a better one from the dealer-I do it.
