H22a Trubo Help NO power
I need some help here, I have a fullly built h22a 9:1 comp hondata 255fp aem rail fpr and only making 200 whp and 209 torqe, anyone have a h22a turbo setup? This is running at 10lbs i am getting these numbers
Originally Posted by DRfrank
werd, and hopefully its at least sleeved..... otherwise.. bye bye cylinder walls :bye:
h22a block
darton 1 peice sleeve
je forged pistons 9:1 c/r
crower titanium retainers
crower rods
mircro polished crank
stainless valves intake and exhuast oversize by .05mm
port/polished head
act xtream with 6puck 494 torqe capacity
hondata s200
450cc injectors
255 walboro intank pump
aem fuel rail
bm fpr
fmic
t3/to4e turbonectics turbo
35mm wastegate
2 1/4 downpipe
think i covered everything and it ws dyno tuned to run the best it could with the problems i am having.
dyno sheets are from my very first run:
this is my 2nd dyno pulls know its not the best but i dont have a scanner now. this was on feb13 05
did they test your compression for you?... are the sleeves installed nice?, they arent like coming undone, i've heard ppl saying b4 that the sleeves start to settle incorrectly and actually start moving in the cylinders...but i'm not compleately sure on that one
Originally Posted by Prelude511
If I were you I would get bigger injectors....like 600cc.....and maybe a better turbo.....but most of all you need an intercooler
