Problems with H22 and ECU
Old Dec 25, 2004 | 04:44 PM
WyldRyde's Avatar
WyldRyde
LudeBoy
Default Problems with H22 and ECU
I cant seem to get everything smoothed out after my H22a. The car was running fine(although it wasn't passing smog) until I put in the p13 ECU. Then it started acting up. When I drive it, it jerks, and looses and gains power randomly. For example when I start off in first it's VERY sluggish to go. But in other gears it jumps as soon as I touch the pedal.
If anyone out there can send me on the right direction to fixing my problems I'd be grateful for the advice. Any questions about the car I can answer. Please help.
P.S. - My friend suggested that it could the fuel injectors, I'm not sure if those had to be swapped with the engine or not.
Old Dec 26, 2004 | 01:52 PM
squee's Avatar
squee
It could be many problems. Assuming that you do not have a cel lit up, check your egr valve, you just perfectly described a problem I had with my h22a, and it turned out to be my egr valve.
Old Dec 27, 2004 | 09:09 AM
ludeboom's Avatar
ludeboom
yes the fuel injectors need to be 345CC from a H22a, the h23a1 injectors are 240cc and the car will not run right with the non-vtec injectors.
~kris
Old Dec 27, 2004 | 01:07 PM
WyldRyde's Avatar
WyldRyde
LudeBoy
Thanks, I'll try swapping the injectors this weekend and let you know if theyfixed the problem.
Old Dec 27, 2004 | 02:19 PM
ludeboom's Avatar
ludeboom
wait so u are using your old injectors right now but you have h22a injectors that you decided not to use? That doesnt make much sense
~kris
Old Dec 28, 2004 | 01:20 PM
WyldRyde's Avatar
WyldRyde
LudeBoy
lol, no. I meant I'll buy the H22a injectors.
