88 prelude vibration at 45mph
Old Aug 18, 2002 | 11:45 AM
EXJXC's Avatar
EXJXC
Default 88 prelude vibration at 45mph
My car viberates at around 40-55 mph. It feels like you are going over rumbel strips. It stops if I stomp on the gas or let off it. It only does it when im going a constant speed. The car is automatic so is the transmission going or is it somthing else? It has no problems or noise when shifting gears. Thanks for any help Eric
Old Aug 24, 2002 | 09:32 PM
SilverSHer's Avatar
SilverSHer
Had the same thing happen in my 88 4ws prelude. It turned out to be loose lug nuts!
You mention it doesn't happen when you brake or accelerate. This makes sense because you are putting torque against the mag in either case. When coasting it will flop around.
Hopefully this hasn't been happening too long, or you might damage the Mag.
Take the tire wrench out of your trunk and give each bolt on each tire a tighten.
Old Aug 25, 2002 | 04:58 AM
fastball's Avatar
fastball
A little chin music
From: Cleveland, Ohio - Rock 'n Roll capitol of the World
Have all four tires checked for balance first. Check your wear as well. If you need new tires up front, replace all four. But first check the balance. You may have lost a weight, and possibly on the back of the rim which you can't see.
Old Aug 25, 2002 | 03:02 PM
Kavikgold's Avatar
Kavikgold
:werd: yep just what i was going to recommend
Old Sep 27, 2005 | 12:00 AM
blokBfiend's Avatar
blokBfiend
Default if
if all of those suggestions dont work check out the lower control arm bushings and upper control arm, my 89 lude did the same. a worn out upper arm will put the car out of alignment
jd_uk
Prelude
4
Jan 16, 2005 12:12 AM
ScoobyDoobie
Jun 20, 2004 11:51 PM
SwiftStreetLude
Prelude
19
Jun 2, 2004 06:24 AM
PlayboyDee
Prelude
6
Mar 17, 2004 08:13 AM
andrew
Prelude
2
Sep 18, 2002 06:10 AM
