5th Gen Prelude..Need help blacking out headlights
Old Apr 28, 2004 | 08:48 AM
homer7198's Avatar
homer7198
Default 5th Gen Prelude..Need help blacking out headlights
I have a 5th Gen Prelude and I would like to black out the headlights to get the JDM look. Has someone ever done it to their prelude? Can someone help...pictures would be great also. I tried using a heat gun around a messed up 5th Gen headlight but the adhesive they use is really strong and using the heat gun and prying it with a screw driver just damages the headlight because the plastic is soft and tender. Any kind of help would be nice. THANK YOU.
Old Apr 28, 2004 | 09:31 AM
nextgenholmes's Avatar
nextgenholmes
Senior Member Wannabe
i am not sure where you could find that but im sure if you contactKing Motorsports they could help you locate that certain part. To tell you the truth i am unsure if that was actually how they look.
good luck
Old Apr 28, 2004 | 11:09 AM
Samson's Avatar
Samson
chris is the devil
theres a write-up on PO.com
Old Apr 28, 2004 | 01:11 PM
monkey's Avatar
monkey
#212
what part of the light are you planning on blacking out? most of it is reflective...
Old Apr 29, 2004 | 09:45 PM
prelude1897's Avatar
prelude1897
You are going to have to heat up your headlights and pry the cover apart in order to paint the crome part of the headlight black. The way I did it was, I put my headlights in my oven at about 350 degrees for about 6-8 min. at a time and check on them in between, then little by little, I pry the cover off with a flat head screw driver....
Old May 2, 2004 | 01:14 AM
homer7198's Avatar
homer7198
Default I did it!!!
I blacked out my headlights.....I'll post up pics when i find my digital camera.
Old May 3, 2004 | 11:44 AM
maweitao's Avatar
maweitao
Do you mean blacking-out the interior? There isnt really anything you can black out on a 5th Gen Prelude. Well, there is, but it will look like crap and the headlights will no longer project light very well.
Old May 11, 2004 | 02:58 AM
drift's Avatar
drift
Flaccid Member
JDM 5th gen headlights are identical to the ones you have. i know this because I used to live in Japan.
92CivicDX
92+ Civic/EL & Del Sol
32
Feb 4, 2004 06:51 PM
thekrohn
Accord
13
Nov 27, 2003 05:05 PM
ShupaLude
Oct 18, 2003 12:27 PM
MrPreludeSH
Dec 26, 2002 02:35 PM
