Nitrous on an H22A please help
Old Apr 21, 2004 | 02:21 PM
H22ATeg's Avatar
H22ATeg
1995 H22A Integra
Default Nitrous on an H22A please help
Hey i am looking into doing a 65 or 75 shot onto my H22A. (dry) Has anyone here done it? What plugs did you use? what A/F controller did you use and did you retard the ignition? If so by how much? what are all the upgrades that you did to make it work? I am looking into doing the fuel pump, i don't know if i need to do injectors or the rail right now. Than the controller and ignition timing. i have a MSD 6AL ignition but it does not support timing retard or advancing from what i was told. Any help would be great.
Old Jun 4, 2004 | 07:17 AM
zexylude13's Avatar
zexylude13
98 Prelude
I have a 55 dry shot on my H22A. I have an adjustable fuel regulator and a V-afc. I got on the dyno and was running way rich. I adjusted the fuel curve with the V-afc and now everything is perfect. I am using Zex plugs and i didnt retard the ignition becuase im only running the 55 shot. I have thought about bumping up to a larger shot but havent done it yet. i have a stock fuel pump and injectors. hope this helps.
oc_civic
92+ Civic/EL & Del Sol
10
Jan 1, 2006 02:51 AM
VN-TEC
12
Oct 28, 2003 08:41 PM
LilDragonTKD
9
May 9, 2003 05:51 PM
Widebody NSX
Nov 7, 2002 07:18 PM
