reset check engine light
Old Oct 30, 2003 | 06:50 PM
mole's Avatar
mole
Default reset check engine light
My check engine light came on, i fixed the problems with the codes it gave me and now i just want that damn light to go off.. how can i reset it without having to take it to Honda?
98 lude btw
thanks,
Old Oct 31, 2003 | 12:32 AM
monkey's Avatar
monkey
#212
disconnect the battery.
Old Oct 31, 2003 | 05:59 AM
97PreludeSH's Avatar
97PreludeSH
easier yet, just pull the fuse for the radio and clock. Either way, make sure you have the security code for the radio, or else you'll have to make a trip to the dealer after all.
Old Nov 1, 2003 | 01:27 AM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
so if i pull the fuse on the clock and Radio, will the light go away?
wut if i pull the ecu fuse?
Old Nov 1, 2003 | 06:16 AM
97PreludeSH
same fuse.....fuse box is just labeled clock/radio. Just yank the fuse for about 10 seconds and the ecu will reset.
Old Nov 11, 2003 | 09:36 AM
sphinx054's Avatar
sphinx054
disconnecting the battery will do it personally i would try hooking it up to a scan tool and resetting it and while your there check to make sure that your repair did infact fix the problem on my 96 ford taurus the check engine light was on because of a misfire in cylinder 5 and insufficient flow in the EGR(exaust gas recirculation) i changed the plugs and wires that fixed the misfire then i removed the EGR valve and tube and cleaned the hell out of it but guess what it didnt fix my problem i eventually gave up cause i had to get it inspected and it wouldnt pass with the check engine light on it was actually on because the EGR sensor was malfunctioning after that was fixed the light didnt come on anymore. thats just some food for thought and im not completely sure but if you have OBD2 if the computer doesnt see a Diagnostic Trouble Code in 3 OBD2 trips then the code is ignored and the light should turn off. hope my info is helpful keep me posted.
Old Nov 11, 2003 | 11:00 AM
ludeboom's Avatar
ludeboom
yup :usa:
