Anyone interested in this X bar?
Old Nov 19, 2002 | 09:23 AM
ITRinEJ1's Avatar
ITRinEJ1
Default Anyone interested in this X bar?
just in case if some of you didnt catch it, there is now a Groupbuy going on for this. here's some info copied from my site:
Some info on the brace: all bars are made of aluminum, 30mm in size. Only 30mm is available, 22mm has been discontinued. Included is the C-pillar bar as seen in picture above (the top bar going across bolted to the rear seat belt harness), and the cross/x brace that crosses each other. We have confirmed that the stock rear seats can be kept with this setup as well!! The only issue is that the backing of the rear seat will slightly touch the bar so it is STRONGLY RECOMMENDED that there should be no passengers in the rear when this bar is installed. Also, you must run an aftermarket rear strut tower bar in order to complete the pivot/mounting points on the bottom. Cockpit Loft recommends using Cusco bars. Any other bars types of bars, they do not know if it will work or not, just that they know FOR A FACT any type of Cusco rear bar will work with this setup. Finally, a nice positive about this product is that it is a simple bolt-on/bolt-off piece so for track days you can simply bolt it up (should take no more than 10-15 minutes to complete all work) and at the end of the day take it right off just as easily!!
Some points to consider before you want to join the Group buy on this product:
1) The purpose of this setup is to help stiffen the rear chassis; this in NO WAY SHAPE OR FORM replaces or takes in the same functions (such as rollover safety) as a roll cage!!!
2) This setup is also STRONGLY NOT RECOMMENDED for mounting or bolting on race harnesses; again that is NOT the purpose of this product!!
3) AGAIN, this is only for DC2!! Please don't waste my time and ask can i make this fit my EG or EK because my answer will be a BIG FAT NO!!!
OK now for the fun part!!
All prices below, we need 10+ buyers to make this happen!!
30mm X-Brace: $360
Package deal for Cusco rear strut bars with the X-Brace (This price is ONLY valid with the purchase of the X-Brace!!! NO EXCEPTIONS!!)
X-Brace + Cusco Type AS bar (32mm aluminum oval): $460
X-Brace + Cusco Type OS bar (40mm aluminum flat): $485
X-Brace + Cusco Type 40 bar (40mm aluminum oval): $510
X-Brace + Cusco Type CB bar (40mm carbon fiber oval): $540
Flat rate shipping of $25 for combo above in continental US!!
**Customers not in continental US please email me for shipping quote.
**Pickup available in Bay area, CA; In that case shipping fee is waived!!
Old Nov 19, 2002 | 09:30 AM
crash's Avatar
crash
im interested because my car got hit in the rear right side and damaged the frame so im trying to strengthen the rear, i got upper and lower bars there now, you think this x bar would help? or would it harm my car?
Old Nov 19, 2002 | 01:21 PM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
You have frame damage? You would be better off trying to straighten it out...I'm surprised your car wasn't written off as totalled...most insurance companies usually do.
The xbar would definitely strengthen your rear, but I'm thinking the bent frame will still give you quirky handling characteristics. You may as well save up for a rollcage (with removable x-brace)
Shingo
Old Nov 20, 2002 | 09:15 AM
ITRinEJ1's Avatar
ITRinEJ1
uhh yea....j000 need to fix j000 frame first before you do any more mods, or better yet find another car!!
Old Nov 21, 2002 | 03:52 PM
crash's Avatar
crash
i had the frame pulled right away, it wasnt drivable with the frame bent i had a bent upper control arm and bent shock, which were replaced. the only thing i need to replace now is my rear quarter panel. i think i might add a roll cage, anyone know if they make a roll cage that is just for the rearhalf of the car?
oh and my handling is fine
