Midsize Sedan V6 shootout: Accord vs Fusion vs Sonata vs Camry
Originally Posted by asianautica
And that matter becuase? I bet the whole Subaru production capacity doesn't match the production capacity of just the Accord or Camry. If you use the logic, then the Ridgeline shouldn't be compare with other mid-size trucks or the Tundra/Titan shouldn't be compare w/ the F150/Ram/etc.
I think the point of the comparison was to test the standard, middle of the road family sedan. And the Subaru Legacy is just a little too far from the mainstream of the market for that role. Whoever said that bit about this not being an all-encompassing test hit it right on. My guess is that when the Passat 3.2 4Motion (or better yet if VW would bring out a Passat 2.0T 4Motion) comes out next year, that would be an excellent car to compare against the Legacy.
As for the Ridgeline, it absolutely should not be compared with other midsize pickups, not because of production capacity but because it's not one. It's an SUV with an open bed, a la Explorer Sport Trac, Chevy Avalanche, or Escalade EXT.
Originally Posted by Troopa-R
Production numbers aren't a reason not to compare vehicles, although they probably played a part bringing the Camry and Accord into the comparo. However, the Legacy isn't an accurate fit into this comparison. If you read the MT article, they even admit that they were looking for a particular criteria of car, that they accidentally ordered the wrong Accord (and EX V6 with Navi), they had to take that into consideration with their evaluations, and that the appropriate model would be the LX V6.
The new Passt 3.6 AWD is probably going to tip the scales at around 40k. Price it right and you may keep it near $35k. I don't think people will cross shop the Passat and Legacy.
Check out this page:
http://s87049031.onlinehome.us/magaz...sizeSedan7.JPG
The first paragraph calls the design for a loose manufacturing tolerance on the Fusion's panels "sensible." Then bashes the shoddy result...
And it still finished second?
basically, it'd be a good idea if they did it correctly - but they didn't, so it was a bad idea.
edit: that wasn't the only negative about the car, either, or the only reason it came in second. its also interesting that both magazines ended up with the same rankings. i wonder if the next camry, or maybe the generation after that, will respond better.
Originally Posted by M Type X
Hot like yesterday's Krispy Kreme. The concept looked so sleek. Oh well.
If they ever remake "shaft" or "dolomite" they should cast that as the "star car"
