Minivan, SUV, & Truck RDX, Ridgeline, Element, Pilot, MDX, CRV, Passport, Odyssey, and SLX.
CRV Braking Noise
Old Dec 23, 2002 | 07:43 AM
BrandonT's Avatar
BrandonT
Default CRV Braking Noise
Does anyone else have a noise when they hit the brakes for the first time? Here is the scenario: I back down the driveway, hit the brakes and get a metallic 'clank'. Put the car in drive, go down to the corner, hit the brakes, clank again. This won't happen again until I change direction (IE: Put the car in reverse). Dealer says this is normal, but it definitely doesn't sound 'right', especially for a Honda. My best guess is too much play in the caliper mounting, or slop in the transmission. Probably the brakes since it only happens once, on deceleration.
Old Dec 23, 2002 | 10:02 PM
bzarkout's Avatar
bzarkout
It happens to me too.
Old Dec 24, 2002 | 06:45 AM
BrandonT's Avatar
BrandonT
After some more research last night, I found an answer on hondasuv.com. (Sorry, H-A) The noise is from the brake pads shifting inside the caliper brakets. Whenever you change direction, you put a different force on the pads, which forces them from one side to the other. Frankly, it sounds like they just don't fit right. I will post again if I find another set that doesn't do this.
