Minivan, SUV, & Truck RDX, Ridgeline, Element, Pilot, MDX, CRV, Passport, Odyssey, and SLX.
((((((((((oil leak))))))))))
Old May 2, 2006 | 01:27 PM
senna's Avatar
senna
Default ((((((((((oil leak))))))))))
My trusty and reliable 1995 Honda Odyessey has given me cause for alarm by leaving drippings under the engine bay.
On inspection, the oil seems to be coming from no where. Knowing this is impossible, I searched and alas a site in the middle of the timing belt cover looked soiled.
A quick search and stories of a "cam balancer seal" or "front balance shaft oil plug" reveals a history. Some mention a Recall went out?
Is it a reasonable asumption that this is my problem and info. on a fix would be greatly appreciated.
Thank You,
senna
Old May 2, 2006 | 04:59 PM
honda guy's Avatar
honda guy
Well if the timing cover is wet the only thing to do is to start taking it apart. There is a cam, crank and a balancer seal beind there. There is also an oring for the rear balancer assly that could leak. You really won't know till you get in there.
Old May 2, 2006 | 06:24 PM
sherwood's Avatar
sherwood
I missed Sean
h22 swap h:
Old May 2, 2006 | 08:38 PM
jaje's Avatar
jaje
HC Racer H5
take it to a dealer and have them check it out to confirm that is the problem and to confirm if its subject to the recall
Old May 2, 2006 | 09:37 PM
senna's Avatar
senna
Yes I really won't know the location of said "oil leak" untill removing the plastic upper timing cover. I suspect the front balance shaft seal/o-ring.
Hoping someone has knowledge of a similiar problem and can suggest whether to buy the part and rip into this area. The Do's and Dont's if you will? Will contact Honda tomorrow to see if a recall existed?
Thanks for the replys!
senna
Old May 2, 2006 | 09:53 PM
sherwood's Avatar
sherwood
I missed Sean
talk to the accord people, they should be able to help you out as the engines from the 94-02 accords were very similar and from the same engine family
Old May 4, 2006 | 04:32 PM
HostileJava's Avatar
HostileJava
Yeah, that's the same engine as the 94-97 accord owners have.
Old May 7, 2006 | 04:46 AM
honda guy's Avatar
honda guy
That recall has expired. It has a time limit on it and it passed about 2 years ago.
Read page 4 of the attachment. under what to do it says until January of 2003.
File Type: pdf
