Minivan, SUV, & Truck RDX, Ridgeline, Element, Pilot, MDX, CRV, Passport, Odyssey, and SLX.
clock light bulb replace for oddysey?
Old Oct 15, 2005 | 06:49 PM
pgchang2000's Avatar
pgchang2000
Default clock light bulb replace for oddysey?
Does anyone know how to replace the clock bulb on 2000 oddysey EX model?
Old Nov 19, 2005 | 08:49 PM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
first put the transmission lever into "1" or all the way down. Then remove the panel around the radio, you can remove the square plastic plug on the bottom left of the radio panel with a small screwdriver put your finger in the hole and pull out the panel carefully. You will see that the panel extends to just underneath the shift lever. Once it's free, unplug all connectors and set it on the pass. seat. Then remove the phillips screws just under the clock/vent assembly, now pull it out carefully on the right side and bend it back(be extremely careful) enough to access the small little bulb.(look at your new one for referance) carefully unscrew it and install your new one, reassemble everything, that's it.
Old Nov 20, 2005 | 06:54 PM
honda guy's Avatar
honda guy
The panel to the left of the coulmn with the door switches has to be removed two. There are 2 screws behind that and the two that go up by the gauge cluster
