Minivan, SUV, & Truck RDX, Ridgeline, Element, Pilot, MDX, CRV, Passport, Odyssey, and SLX.
2005 Pilot Octane Recommendations
Old Dec 21, 2004 | 07:13 PM
mffdvr's Avatar
mffdvr
Originally Posted by DRfrank
um.. did you just say you switched to a suv to get more for your gas money?
does that sound really odd to anyone else?
Well, I said it assuming that these pilots used regular, not premium gas.
Old Dec 22, 2004 | 06:00 AM
CarlosT's Avatar
CarlosT
The 2005 brochure sez regular with premium recommended for towing.
Old Jan 12, 2005 | 06:39 PM
cwa107's Avatar
cwa107
The spark advance is automatic and is adjusted by the ECU. Someone suggested that running 87 could damage the vehicle. This is simply not the case. However, if you do run higher octane fuel (91 or above), you will gain additional HP. If you choose to run 87 (which the Pilot was definitely designed to run), you will achieve the standard 240hp. Otherwise, there will be no adverse effects.
