Thinkin about buying a legend, Need info!
Old Feb 17, 2003 | 06:40 PM
Killuminatic's Avatar
Killuminatic
Default Thinkin about buying a legend, Need info!
Which model and year is the best legend from your opinions? Im thinkin about pimping a legend out, they have nice headlights.
Old Feb 18, 2003 | 10:53 AM
Killuminatic
Old Feb 20, 2003 | 02:30 AM
Dave C's Avatar
Dave C
The most desireable are the 94-95 LS 6 speed coupes followed by the 94-95 GS sedans. Best performance would be a 93 L 6 speed coupe (lowest weight).
Be aware there is very little aftermarket for the car and wheel fitments are a b!tch (+65 mm stock).
Old Feb 20, 2003 | 05:52 AM
daddykay24's Avatar
daddykay24
91 to 95 legends you cant go wrong with any one of these. I have a 92 I use as my work car and its the best car I've ever had.
Old Feb 20, 2003 | 06:54 AM
DAFUNK99's Avatar
DAFUNK99
what about a 1988 Legend with 250,000 (KM) clicks. Someone is selling it a is. What should I look out for? Tyring to help out a friend.
Old Feb 20, 2003 | 07:20 AM
Dave C's Avatar
Dave C
Most common problem with the G1's is rust around the filler neck and rear wheel wells. Make sure all electricals are working correctly. Bouncy speedo means cable needs to be lubricated. Blinking drive indicator light (auto trans) usually means bad Vehical Speed Sensor.
Have an independent Honda/Acura specialist check the car out before handing any money over or signing anything.
