Remote starter
Old Jun 18, 2002 | 06:21 PM
TGXIII's Avatar
TGXIII
Default Remote starter
Does anyone know if it's possible to install a remote starter to a 1996 RL? I'm not sure how it would work with the factory remote keyless entry system, if I have to remove the factory system to install the remote starter or whatever. If it does work with the factory system, can someone explain what I should do when I install a remote keyless entry system?
Old Jun 20, 2002 | 12:27 PM
katskilz's Avatar
katskilz
I know you can but I don't no how, if your not to sure about how to do it have someone who's knows what there doing install the remote starter. And I believe it doesn't work with your factory alarm it would be separate.
Old Jun 20, 2002 | 02:16 PM
TGXIII's Avatar
TGXIII
so I can install a remote starter but my factory alarm will still be intact? ill look for someone to install it for me, but i wanna know if i can still use the factory alarm in conjunction with the remote starter because some remote start systems come with an alarm.
Old Jun 21, 2002 | 08:45 PM
fastball's Avatar
fastball
A little chin music
From: Cleveland, Ohio - Rock 'n Roll capitol of the World
You can purchase a separate remote start unit that does just that. You can still use your factory remote entry/security, but the only drawback is that you will have two separate remotes. It's a fairly simple installation for anyone who's done remote alarms, starters, etc.
Old Jun 21, 2002 | 09:40 PM
TGXIII's Avatar
TGXIII
thanx everyone who posted. you guys were a lot of help. one more question: does anyone know any good remote starters that has the option of turning on the climate control of your car also? im looking for one that doesnt come with a remote keyless entry or a car alarm so i can still use my factory one.
Old Jun 28, 2002 | 10:16 PM
fastball's Avatar
fastball
A little chin music
You should be able to find a remote starter just by itself. When you have it installed, ask the technician who will be doing it to tie the starter to the climate control. They will have to run an output from the starter to the climate control accessory line, and it will remember the setting you had when you shut the car off last time. Just remember to ask the installer to do that for you (some places may charge a little extra labor for that)
DOZ5
Accord
7
Nov 19, 2007 12:37 PM
