B17a1?
Old Oct 4, 2003 | 10:15 PM
HondaFreak6's Avatar
HondaFreak6
Default B17a1?
Is this the right engine code for the 92-93 Integra GS-Rs? How come you dont see these engines built up like u do B18s all tha time? Also, what is tha chassis code for 90-93 Integras? DA?
THanks
Old Oct 4, 2003 | 10:18 PM
TarHeeL-Si's Avatar
TarHeeL-Si
is your car a 1.7 liter or 1.8 because thats what that stands for, figure that out and you should knwo the answer
Old Oct 4, 2003 | 10:24 PM
DelSolSIinMD's Avatar
DelSolSIinMD
Le Grand Illusion
Yes, B17a1 is the engine for the G2 Integra GS-Rs. Why aren't more built up? Simply because very very few 92-93 GS-Rs were built. I think the chassis code for 90-93 Integras was DA6.
Old Oct 5, 2003 | 12:04 AM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
They were also stroked out B16s, which'll run you into more stability issues with turbo and such over a B18C1, which get their larger displacement from wider cylinders...
Old Oct 5, 2003 | 03:54 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Incorrect.
All B-series motors have an 81 mm bore, except for the B20B and B20Z which have an 84 mm bore.
Old Oct 5, 2003 | 09:43 AM
Epoch's Avatar
Epoch
Erp... my bad then... so the differences in displacement between the b16-b18 are in the stroking?
Old Oct 5, 2003 | 01:54 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Everything from B16A to B20A5 is 81 mm bore with strokes ranging from 77 to 95 mm.
The B21A1 ('90-'91 USDM Prelude Si) was basically a B20A5 (95 mm stroke) with an 83 mm bore.
The B20B and B20Z are variations on the B18B (89 mm stroke) but with an 84 mm bore.
The B18C has an 87.2 mm stroke, the B17 is 81.4, and the B16 is 77.
Old Oct 5, 2003 | 03:51 PM
Epoch's Avatar
Epoch
Wow... thanks.
Old Oct 7, 2003 | 02:13 PM
sick79's Avatar
sick79
90-93 rs, ls and gs is da9. 92-93 gsr is da6.
Old Oct 7, 2003 | 07:48 PM
Ice025's Avatar
Ice025
I know a kid who has a mint 93 gs-r just sittin around in his yard. The engine needs a rebuild so he can't drive it. The car hasn't moved in almost 3 years. I wish I could get this kid to sell it to me. They really are pretty rare cars. I've only seen a few.
