car died
Old Sep 22, 2003 | 11:33 AM
dave0283's Avatar
dave0283
Default car died
last night i was driving and slowly the car started to die out. The headlights, dash lights, power windows, all stopped working and the car would not accelerate anymore. Eventually it just died. After letting sit for a half hour or so, waiting to get towed home by a friend, the car started up agian (i guess the better had some juice left) but same thing happen again as i try to drive it. I think the alternator might be bad but wanted to get some feed back. all help is appriciated.
P.S. the car started up this morning again but slowly the lights were dimming out and the engine would die.
Thanks
Old Sep 22, 2003 | 11:36 AM
puffy's Avatar
puffy
bow down to king puffy
battery?
Old Sep 22, 2003 | 11:39 AM
dave0283's Avatar
dave0283
shouldn't the car run once it is started since the alternator charges the battery. I had the car in the dealer two weeks ago to change the alternator and i think those "professionals" screwed up or something.
Old Sep 22, 2003 | 11:59 AM
Daniel's Avatar
Daniel
Check your alternator to battery connections. Your altenator may not be connected properly and is not charging your battery thus it is running down on you.
Old Sep 22, 2003 | 01:03 PM
dave0283's Avatar
dave0283
is there a way to test the alternator?
Old Sep 22, 2003 | 01:15 PM
JimBlake's Avatar
JimBlake
First, check all cables, both ends. Including the cable that grounds your transmission to the chassis.
When the engine's running, the battery voltage should be around 14v. Leave it running, turn on headlights, blower, defogger, stereo... It should still be around 14v. If it drops much, your alternator is weak.
Old Sep 22, 2003 | 01:35 PM
dave0283's Avatar
dave0283
lets assume the alternator is bad, if i throw in a new battery will it get drained quick, or will it last a while?
Old Sep 22, 2003 | 02:55 PM
OregonHusker's Avatar
OregonHusker
There sure is. You can have it done at Autozone and get your battery tested as well.
Old Sep 24, 2003 | 10:35 AM
dave0283's Avatar
dave0283
changed the battery and also had to change a fuse. the fuse was the fault. thanks to all.
Old Sep 26, 2003 | 09:50 AM
rsteg's Avatar
rsteg
depends how bad the alternator is. but in any case it will not last long.
