low idle 95 ls
Old Sep 19, 2003 | 06:03 AM
karlt10's Avatar
karlt10
i don't know about marvel mystery specifically, but some cleaners recommend a certain schedule to use them- like stp's complete fuel system cleaner says not more often than every 4000 miles- but if marvel doesn't say- i'd keep using it. i use chevron techron about every 2-3,000. once a year, usually spring, i use SeaFoam in a tank as i head out on a highway trip.
cleaner or not, there would have to be 'junk' in your tank to be broken loose by the cleaner- that would still worry me a bit
Old Sep 19, 2003 | 03:12 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
See if you can get your hands on a known-good IACV and switch it into your car temporarily. If it idles fine then you know you need to replace your IACV. Otherwise you can buy a new one and if it doesn't fix the problem then you could try to sell it or something. But I would try to find a known-good one first.
Also you may have something as simple as the vacuum hoses running to and from the IACV being messed up going on.
Old Sep 20, 2003 | 01:15 PM
Driver's Avatar
Driver
slow lane cruiser
the vacuum hoses on my iac (when I cleaned it) both had coolant in them, one of the hoses runs to what i believe to be the fast idle thermo, the other i dunno
1. is there suposed to be coolant there(i think yes but i am uneducated)
2. Should a manual tran engine have the FIT?
Old Sep 20, 2003 | 01:39 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Yes the IACV has coolant lines plumbed to it. All cars have a fast idle thermo valve regardless of AT or MT. The thing that only AT cars have is a starting air valve.
Like I said man it's probably a bad IACV.
