my car kinda hesitates during changing gears in my auto LS
i noticed when taking off sometimes fast, my car hesitates before it changes gear, i tried changin out spark plugs but that didnt fix the problem, and my car sometime has trouble starting off slow when i turn on the ignition, do you guys know what the problem is?
could be one of two things, the wrong tranny fluid (or fluid is dirty) or the engine is cold. If the engine is still cold (early in the morning) the transmission will lag a bit, and common among G3 teg owners.
How much mileage is on your car? It's quite possible your tranny is just going. My mx6 is like that and it's slowly dieing. That is a early warning sign. Could be something else though (hopefully).
Re: my car kinda hesitates during changing gears in my auto LS
Originally posted by maldini
What type of compounds are in Honda ATM that make it special?
That includes tranny filter and fluid change. I'd also put an external tranny cooler. That keeps it cool so it won't wear quicker. Hope it goes fine. Keep us updated.
There are 2 methods that you can use to change the fluid. The easier method is to just open the drain plug and refill w/~4 qts. The problem with this method is that you're on changing part of the fluid and not replacing the fluid in the torque converter.
If you want to change out all the fluid, you can either; 1) have a shop flush the transmission using a pumping system or 2) do a "triple" flush ( basically changing the ATF 3 times, while the car is running.)
