suspension question
Old Jul 8, 2003 | 04:08 PM
AciDKinG95LS's Avatar
AciDKinG95LS
SOLD THE ALLUM. WING!!!!
Default suspension question
I ordered a set of 4 struts for my 95 teg ls. 2 front and 2 rear. I also ordered a set of kyb agx adjustible shocks. Im beginning to wonder if i need the struts, because in the title of the kyb shocks it said they were "shock/struts" I know all of you guys know the answer to this. A wuick response would be great cause i could save alot of money.
Old Jul 8, 2003 | 10:20 PM
surferkai's Avatar
surferkai
correct me if i'm wrong, but i think they usually to the shock absorbers as shocks or struts. i've heard both. so you may have ordered too many things. my understanding of things is that the strut or shock has the coil spring over it, which one end is bolted to the top of the wheel well, and the other is attached to the suspension arm which the wheel is on. so go with the kyb adjustables. what kind were the other 4 that you ordered? if you need to sell a set, let me know.
Old Jul 9, 2003 | 03:32 AM
AciDKinG95LS
they are megan struts, i have already paid for them. Is it good to have both shocks and struts? If i do not need them, 0r if they do not work to my advantage i would sell them reasonably.
Old Jul 9, 2003 | 05:24 AM
teg_fan's Avatar
teg_fan
I like integra's
you only need one set of 4 shocks(same thing as struts). So you should sell or cancel one set of them. Now all you need is a set of springs.
Old Jul 9, 2003 | 05:43 AM
AciDKinG95LS
i thought struts were bars that attached the two front/rear wheels together? do shocks do that?
Old Jul 9, 2003 | 08:08 AM
Taiwanze7's Avatar
Taiwanze7
CivicSiRacer
Most cars with double a-arms like pre-2001 Civics have shocks. Keeps the wheels/tires more planted on the ground. Whereas the strut is part of the suspension that it is integrated into the a-arms.
strut bars is a bar that attaches to the top of shock/strut. regardless shocks and struts serve the same function, so you essentially bought two of the same thing.
Old Jul 10, 2003 | 02:45 AM
AciDKinG95LS
so there is no advantage to having shocks and 4 strut bars? If no, IS ANYONE INTERESTED IN BUYING 4 NEW STRUTS?
