Crank pulley tool
Old Jul 7, 2003 | 07:56 PM
stevieteg's Avatar
stevieteg
Default Crank pulley tool
Where can I find a crank pulley tool? I called the honda dealer and they don't carry them. I might have to make my own, using a 2" pluming fitting and a pipe welded together. Any advice?
Old Jul 8, 2003 | 02:10 AM
Mystikallobster's Avatar
Mystikallobster
are you trying to remove the pulley? just use a socket and some kinda pipe or bar to brace it
Old Aug 16, 2003 | 06:22 PM
ldodol's Avatar
ldodol
i believe he is talking about the tool to keep the pulley in place while he is unbolting the bolt.
you can try a local car parts store for the pulley holder. (e.g. kragen, pep boys, or napa auto parts)
Old Aug 16, 2003 | 11:04 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
moroso makes one. contact them
works great...
Project EVA - The Track Package
Project EVA
Old Aug 18, 2003 | 03:15 PM
stevieteg's Avatar
stevieteg
oddly enough I found out you can just use an impact wrench. No special tool is needed.
Old Aug 18, 2003 | 09:02 PM
ldodol's Avatar
ldodol
i've heard that it isn't a good idea to install a crank pulley with an impact wrench because it can cause some damage.
Old Aug 19, 2003 | 08:24 AM
Daniel's Avatar
Daniel
An easy method is to remove the small metal flywheel panel that protects it from debris located beneath the engine. I pinned a fat screwdriver in there between the flywheel teeth and used the oil pan and header (if I remember right) to pin it in place. Taking a BFH to the socket wrench broke it loose with a couple of smacks.
Old Aug 19, 2003 | 02:21 PM
stevieteg's Avatar
stevieteg
I had went to the honda dealer looking for the special tool, they looked at me funny and said just use an impact wrench.
