what should my next mod be performance wise
Old Jul 9, 2002 | 09:00 AM
StyleTEG's Avatar
StyleTEG
Make me an offer
You will only lose power if your exhaust piping is to large for the amount of power your engine produces. Oversized piping hurts exhaust velocity, since exhaust pulses are too small and no longer exit in a striaght mannor. Instead they bounce off the inside of the pipes, thus slowing down.
Like this
A properly sized exhaust system for your engine output (or future output) will not cause perticular low end problems.
Make sure your collector, cat, and exhaust piping fit your overall goals for engine performance.
It will add HP, because you have a bottleneck at your cat right now. Quality Carsound cats flow almost as well as a test pipe, and it will be 2.25" (or bigger depending on your exhaust diamater) instead of 2".
2-1/4" up to 210HP @ the flywheel (about 180-185 whp)
2-3/8" (60mm) up to 235HP @ the flywheel (about 200-207 whp)
2-1/2" up to 265HP @ the flywheel (about 225-235 whp)
2-3/4" up to 325HP @ the flywheel (about 275-285 whp)
3" big for big HP (Forced Induction: > 275 whp)
Old Jul 9, 2002 | 07:07 PM
pomansouth's Avatar
pomansouth
how much are most sets of cams ive been seeing like 600 is that reasonable or not. i forgot what kind they were but i just want to know how many horses and stuff like that will i get out of them bad boys
Old Jul 9, 2002 | 08:02 PM
qtiger's Avatar
qtiger
A smaller exhaust will benefit low end torque, at the sacrifice of power.
You can't have a properly sized exhaust for 750 rpms to 8000 rpms.
Old Jul 9, 2002 | 09:28 PM
98redgsr's Avatar
98redgsr
i would say turbo if u have the money to spend on it.
Old Jul 9, 2002 | 11:02 PM
pdcdragon's Avatar
pdcdragon
What kind of budget are you workin with here? I think the best advice that people give on this board are those with some amount of organized plan. Make a goal for what you want out of your car and work towards it. But high profile cams and some adjustable cam gears will give you some power. If you do decide to get those, you will want the car tuned and get the timing adjusted correctly so you can see the best possible gains from the mods. But forced induction(turbo/sc) is always on the top of my list, so if you've got the funds to support a turbo motor.... go for it.
Old Jul 10, 2002 | 04:29 AM
StyleTEG's Avatar
StyleTEG
Make me an offer
yup.
I was refering to using a pipe that is to wide for your engine output. IE 3" exhaust on a stock GSR. Even at peak HP you are not generating enough exhaust for the diamater.
RedlineBoyzCRX
92+ Civic/EL & Del Sol
30
Aug 25, 2006 05:11 PM
puffy
Jan 11, 2005 11:45 AM
Mackenzie C
CRX & Pre 92 Civic
6
Dec 26, 2004 09:02 PM
Tirod
Oct 18, 2003 07:51 PM
niko
11
Jul 18, 2003 02:10 PM
