My next mod......what should it be?
Old Aug 24, 2006 | 04:47 AM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
Default My next mod......what should it be?
Well, I have been workin on my new EG car. I sold my CRX that I had worked on for over a year. Now it's time for soemthing new. SO far all I did on it was put a type-r valve cover on, CTR N1 Pulley, ACT Clutch, ACT Prolite flywheel. I have a JG Edelbrock Intake Manifold coming to me this week, I am also installing it with a Hondata IM gasket. Now I can't decide waht I should do next. I was thinking I should do a TB, but I don't know what kind to get. I am not looking at spending a butt load of money on a TB either. They have AEBS one's on Hondamarketplace for liek 180 shipped. That's reasonable. But what size should I get? I want it to be matched to whatever size the IM is, but what size is the IM? 68mm?
Old Aug 24, 2006 | 08:17 AM
shivers's Avatar
shivers
Moderator Alumni
If you're dead set on a TB, send your stocker to http://www.maxbore.com/
He's been boring TBs for years and does excellent work. He can also port match the IM. Aftermarket TBs can be finicky.
Truly, without a set of BIG cams and other supporting mods, a larger TB isn't going to get you anything but a lighter wallet.
2005 s2000
Old Aug 24, 2006 | 09:14 AM
RedlineBoyzCRX
EG6
here are my mods.
Engine:
B16a Swap
Buddy Club Pro Spec Exhaust
CTR N1 Crank Pulley
Magstar 8.5mm Wires
Civic Type-R Cams
JG Intake Manifold
Short Shifter
Test Pipe
Type-R Valve Cover
Transmission:
ACT Clutch
ACT Prolight Flywheel
Suspension:
Koni Adjustable Shocks
Ground Control Coilovers
Front Strut Bar
Neuspeed Rear Strut Bar
Exterior:
Rota Group N Rims
VIS CF Hood
Projector Headlights
Interior:
Autometer 5" Tach
SiR Gauge Cluster
Type-R Steering Wheel
Old Aug 24, 2006 | 09:53 AM
shivers's Avatar
shivers
Moderator Alumni
CTR cams are in no way big enough to warrant a large TB. The IM you're getting is border line too big as well. Boring the stock TB won't hurt, but it won't help either.
The best thing you could do would be to save your money for a quality header and some form of engine management. Only when you reach the point of not having enough air flow, should you consider things such as larger TBs, big IMs, etc.
2005 s2000
Old Aug 24, 2006 | 01:47 PM
RedlineBoyzCRX
EG6
Well, I plan on doing a turbo setup on the car, The only reason I want a Port Match TB for the IM is so that when I go turbo I will have all the little things that will complement my turbo setup. The reason I got the edelelbrock IM is because I checked all reviews about IM's and asked opinions, and all I came back with was Edelbrock. Obviously I would rather have Full-Race, but it is too expensive. So the next best thing is edelbrock. I don't want to buy a header for my car, becasue I am going to have to sell it when I go turbo. Also I have a Apexi VAFC 2, I jsut haven't had a chance to go install it and go get it tuned.
Old Aug 24, 2006 | 02:37 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
If ur gonna to turbo the car, get rid of the crank pulley for a fluid damper, and get a stock flywheel, I was talking with someguys when David was dyno'n his del sol, and they siad that the CTR pulley will blow out the oil pump and take out the bearings.
Old Aug 24, 2006 | 02:46 PM
ReVenGe's Avatar
ReVenGe
are you all done with exhaust? i didnt see a header... but i gues youd be saving that if you went turbo... what about stiffinin your frame? sway bars etc
Old Aug 24, 2006 | 04:29 PM
shivers's Avatar
shivers
Moderator Alumni
If you're going to post questions asking about parts to consider, at least share what the ultimate end goal is so people can actually help. Exhaust work will be essential for good turbo performance.
2005 s2000
Old Aug 24, 2006 | 09:55 PM
BtTurboM3's Avatar
BtTurboM3
Originally Posted by RedlineBoyzCRX
here are my mods.
Engine:
B16a Swap
CTR N1 Crank Pulley
Magstar 8.5mm Wires
Civic Type-R Cams
JG Intake Manifold
Short Shifter
Test Pipe
Type-R Valve Cover
Transmission:
ACT Clutch
Suspension:
Front Strut Bar
Exterior:
Rota Group N Rims
VIS CF Hood
Interior:
Autometer 5" Tach
SiR Gauge Cluster
a little off topic but....pics? just out of curiousity
Old Aug 25, 2006 | 12:15 AM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
Im not really a forced induction guy...but I was thinking if CTR cams would be kinda too agressive for forced induction? :dunno:
