Brake Rotor Question
Old Jun 28, 2003 | 10:15 AM
Ice025's Avatar
Ice025
Default Brake Rotor Question
How important is it to use the 2 set screws that hold the rotors on? I just did the front pads and rotors on my teg and on both sides of the car the 2 screws that hold the rotors on were all rusted and stripped. So i had to fight like a bitch to get the rotors off and had to reassemble everything w/out the screws. I was told by a friend that you really dont need the screws. Anyone know if this is true?
Old Jun 28, 2003 | 11:59 AM
3 plus 1's Avatar
3 plus 1
If it came from the factory with it, use it. Dont ghetto-rig stuff together. It'll catch up to you in the long run.
Old Jun 28, 2003 | 12:47 PM
stevieteg's Avatar
stevieteg
I had the same problem. I just went to the hardware store a picked up some stainless bots to replace the ones I had to drill out.
Old Jun 28, 2003 | 01:03 PM
Spec R's Avatar
Spec R
Technically you dont need them, but honda put them there for a reason, so get some new ones. Use an impact driver so they dont strip out. Make sure you torque your lugnuts down to exactly 80 foot lbs, in a X-pattern. Improper torquing of lugnuts is the number one cause of rotor warpage.
DB Squad
Integra Forum Moderator
Old Jun 28, 2003 | 01:05 PM
3 plus 1's Avatar
3 plus 1
Warped the rotors on my old pathfinder because the jackasses at the auto shop torqued it down so hard I had to jump on a wrench 3 feet long just to break them loose.
Old Jun 30, 2003 | 05:11 AM
JimBlake's Avatar
JimBlake
You don't need those little rotor mount screws.
Yes, Honda put them there for a reason. They hold the rotor onto the hub during assembly, so they don't fall off while they install the calipers & the wheels.
The lug nuts hold the rotors in place for real. Those little screws sure aren't strong enough to do the job themselves...
