Next mods...
Old Jun 12, 2003 | 06:29 AM
Spec R's Avatar
Spec R
Hmmm I would stay away from engine mods for now, and work on that suspension...hehehe
I'm not talking bars or anything like that, cuz those dont matter if you're going in a straight line, but good a good shock and spring/coilover combo will definitely help your 60 foots.
Tires play a crucial role also. Try a set of Falken Azenis on some 14" steelies, they'll hook up better than your Ecstas, plus you cant go wrong for the price. If you're on 15's or bigger, the 14's will also shorten your LS gearing and also help bring those times down a minor bit.
DB Squad
Integra Forum Moderator
Old Jun 12, 2003 | 06:43 AM
LudeRage's Avatar
LudeRage
I'm on 14's. Perhaps getting springs/shocks would be a good idea. It would look nice by eliminating some nasty nasty wheel gap. Also, since my clutch grabs so hard, when I shift, the back of my car slams...so if I had stiffer suspension, I suppose it would help with that. Cuz I've been wanting to lower my car but favored going the performance route more, but with springs/shocks I can do both
I just got my tires and they actually grab good, so I won't be looking for new ones for awhile. It looks like now I'm probably going for exhaust, then a decent suspension set-up, maybe KYB and H&R or something like that.
Old Jun 12, 2003 | 07:03 AM
LT's Avatar
LT
The deer had to die!
Originally posted by LudeRage
Isn't a Type R intake manifold very similar the the Skunk2? If so, will it bolt right up to my B18A engine? If it does, I can probably get it cheaper than the Skunk2...
The ITR IM will not bolt up to the B18A head. It fits only B18c5 heads or b16a1 heads.
Old Jun 13, 2003 | 03:50 AM
LudeRage's Avatar
LudeRage
Does anyone know how much it is for a shop to modify the header to get it to fit?
Old Jun 13, 2003 | 09:08 AM
Spec R's Avatar
Spec R
There's no way a B16A or B18c5/B18C Spec R exhaust manifold will bolt up to your LS head.
As for the stock ITR intake manifold, i've heard of a few being modified to fit.
DB Squad
Old Jun 13, 2003 | 11:06 AM
LudeRage's Avatar
LudeRage
How is the B18C5 manifold different from the ITR? Isn't it the same car?
Old Jun 13, 2003 | 12:06 PM
Spec R's Avatar
Spec R
the c5 was in the usdm itr's. the b18c with no suffix, serial numbers starting with 19, 20, or 21 are the jdm itr motors.
itr heads are made from the same cast as the b16a head, hence the swappability with both manifolds.
DB Squad
Old Jun 13, 2003 | 12:50 PM
LT's Avatar
LT
uh...i think there's some confusion:
ITR INTAKE manifold won't bolt up to an LS head. However, an ITR EXHAUST manifold will bolt up. The ports are the same size, however, the location of the collector/cat. will be different - so you'll need to extend/shorten you exhaust piping.
Old Jun 13, 2003 | 01:06 PM
LudeRage's Avatar
LudeRage
Gotcha. I was thinking of the ITR header like you said.
Old Jun 13, 2003 | 01:08 PM
Chrgsr96's Avatar
Chrgsr96
Yea I definetly think everyone was mixing things up here.
