Koni install??
Old Jul 5, 2002 | 02:06 PM
Platoon918's Avatar
Platoon918
Default Koni install??
I did a search for this, but didn't find anyone with a decent answer. So...I just got my Koni Yellows in, and in the coming week I plan to install them along with my Type-R springs. My question is, the instructions that came with the Yellows are very vague, and merely show a bunch of pictures. So where can I go to find detailed instruction of an install involving some Koni Yellows and perhaps some sport springs? Thanks for all the help!
Old Jul 5, 2002 | 02:15 PM
Daniel's Avatar
Daniel
http://www.c-speedracing.com/howto/c.../coilover.html
Hope this helps some. If you need tools, you can always do it at my house!
Old Jul 5, 2002 | 02:43 PM
Platoon918's Avatar
Platoon918
Thanks man. Also, its not the tools I need, but the help of some one with prior knowledge. h:
Old Jul 5, 2002 | 02:54 PM
jgrotkier's Avatar
jgrotkier
AIM SN: Johann14420
I'm sure you'll figure it out fine even without someone with knowledge there to help you. When I put mine in, I started while my friend (with prior knowledge) was on his way becuase I was impatient. Well I started working, and I had the whole front done before he even got there, it was a piece of cake (just don't break the bolt off in the rear LCA like I did and you'll be fine )
Old Jul 5, 2002 | 07:18 PM
LudeRage's Avatar
LudeRage
Hey jgrotkier, I was lookin at your car pics and in the first pic of your 91 LS, is that your 95 GSR in the background all torn up?
Old Jul 5, 2002 | 07:29 PM
jgrotkier's Avatar
jgrotkier
AIM SN: Johann14420
yes
Old Jul 6, 2002 | 06:57 AM
LudeRage's Avatar
LudeRage
Geez. What the hell happened?
Old Jul 6, 2002 | 07:08 AM
jgrotkier's Avatar
jgrotkier
AIM SN: Johann14420
https://www.honda-acura.net/forums/s...&threadid=7242
Old Jul 6, 2002 | 02:06 PM
Platoon918's Avatar
Platoon918
I was just looking over the struts today, and I have a few more questions. First, how do you move the spring perch lower? I see there is a removable ring that fits into those notches, but how do I get that off to move it to the lowest notch (thats the one I want if I want the biggest drop possible right?)? Second, I was twisting the now on top to make it firmer and softer and such, but it seemed as if it never stopped rotating. Koni says to stop when you feel resistance, but I definately never encountered any "resistance." Typically how many times does it turn? Thanks.
Old Jul 8, 2002 | 05:32 AM
Black2KGSR's Avatar
Black2KGSR
when the shocks are off the car, it'll keep spinning around because you're turning the whole rod rather than the adjusting mechanism inside. when it's under load, full soft to full stiff is one complete turn (360*). It'll got about 2 full turns, but it's not recommended to go over 1 full turn...and I don't think you'd want to anyway.
as for the spring perch, I have no idea....I couldn't get that thing off myself...so I just left it where it was.
