basic info for lowering
Old Jun 9, 2003 | 09:50 PM
LT's Avatar
LT
The deer had to die!
do you want height adjustability or one time drop? Is this car used in any track events or just for looks?
Old Jun 9, 2003 | 11:49 PM
LALno1's Avatar
LALno1
just for looks, i don't like the tire gap. Eventually I will be getting rims, so i'm looking for something i can adjust in the future
Old Jun 10, 2003 | 12:12 AM
datsurferguy's Avatar
datsurferguy
blah
ground controls are defenitely a good option for adjustability. by far the best imo for coil over sleeves
Old Jun 10, 2003 | 04:33 AM
Deagle's Avatar
Deagle
Nüb
I've got Tein Coilovers, and I'd recommend them as they're ride height adjustable as well as 16 way damping adjustable but if you're going cheaper, I've heard that KYB AGX shocks are decent for the money. For coilover sleeves Ground Controls with Eibach springs, Skunk2s and HP Racing are the most popular. Going one higher on the shocks would get you Tokico Illumina 5 way adjustable.
I find it's really helpful having damping adjustability, since the ride quality can vary greatly, and I'd get sick of getting around on rock hard shocks for daily driving. There's a fine line between rock hard and really bouncy, and it's good to be able to balance the two properly.
Old Jun 10, 2003 | 08:29 PM
ElGouldo's Avatar
ElGouldo
Tein makes a set of mid-range springs called the s-tech. They're Tein, so they're decent quality, and the drop is a reasonable 1.6 inches. Best off, price isn't too bad at all for the S-techs, unlike an all-out adjustable tein system.
Old Jun 11, 2003 | 01:02 AM
integrx's Avatar
integrx
you should also look into camber kits and find an alignment shop
Old Jun 11, 2003 | 07:03 AM
pomansouth's Avatar
pomansouth
ok you need to talk to westcoaststyle on this board because he is the person that will give you the same things for cheaper.
Old Jun 11, 2003 | 07:59 AM
90'RS's Avatar
90'RS
It sounds like you just want to remove the gap and just for looks then. If more for a looks thing I wouldn't go with adj. shock, coilovers or anything like that because this is going to give a real sporty ride and will not be comparible to a stock ride. You can see what I have and I handle a whole lot better and the ride is comparible to the stock ride even though I don't remember what that really feels like. If you want to go sportier other people have made some great reccomendations.
Old Jun 13, 2003 | 01:08 AM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
I would recommend some Ground Control Limited Editions ($299). There are plenty of aftermarket shocks that will work with the GC's, but since I'm a biased GC owner myself I can't really recommend anything short of some pricey Konis.
Shingo
